NON-Flammable tank
发表于 2021-9-1 00:46:54 | 显示全部楼层 |阅读模式
Does anyone know if a tank that had helium be refilled with a mig gas or gas mixture?  I have a  empty tank that had helium in it and would like to get it filled with 75-25 for a mig.
Reply:I swap tanks between Argon for carbon steel and Tri-Mix for stainless steel.  Tell your supplier about the previous tank contents.  To prevent cross-contamination, they should evacuate the tank and/or purge it with the new gas prior to filling it.TeddCoHTP Microcut 400 & Invertig 160DC  Smith Dual Guard MD-510 OA Rig  Lincoln SP135+  Hobart Stickmate LX 235/160
Reply:You won't have a problem.  Both use a CGA-580 valve.You'll just need a new sticker listing the new contents.
Reply:Thanks for the info. Glad to hear the tank is usable.
GMT+8, 2025-12-21 11:47 , Processed in 0.068215 second(s), 18 queries .
