New to Plasma Quick Question
发表于 2021-9-1 00:46:52 | 显示全部楼层 |阅读模式
Ok just bought a New In Box powermax 600 and I really like the quality so far. I may of missed it in the book and did not see in the video but being new to plasma I thought I would ask before assuming something is wrong with a brand new machine. I start a cut everything is fine at end of cut release trigger and I still have air coming out seems it stops only if I depress the trigger again? Is this normal or should it auto stop the airflow immediately?EquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:It should stop after a few seconds.  It is cooling off the torch.A butterfly without wings, is just an ugly bug
Reply:Your manual may refer to that as "post flow". Maybe as long as 20 seconds??
Reply:It's normal, my Powermax 380 does the same thing.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Avoid pulling that trigger extra times.  Each time you initiate an arc at the torch in the air you cause double arcing inside the plasma torch.  The arc travels between the electrode and nozzle shortening the life of your consumables.  Don't start your cut in the air and don't run your cut off the edge of the plate into the air.  Also  torches have a bit of preflow before the arc is initiated.... Perfectly normal.
Reply:"Post flow" is your torches friend."SOUTHPAW" A wise person learns from another persons mistakes;A smart person learns from their own mistakes;But, a stupid person.............never learns.
Reply:Yup, normal.my PM 600 does the same thing!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
GMT+8, 2025-12-21 11:44 , Processed in 0.103339 second(s), 18 queries .
