Earth lead length ?
发表于 2021-9-1 00:46:49 | 显示全部楼层 |阅读模式
My MIG welder has a 10 metre remote feed set up on it which is really handy, but the earth lead which clamps to the work piece is only about 2 metres long, which sort of defeats the purpose of having such a long remote feed.Can I extend or replace with a longer earth lead, and if so, how long can I go without causing problems ?
Reply:yes size wire to be adequate for hghest ampsyou can run for the distance you want
GMT+8, 2025-12-21 11:58 , Processed in 0.221405 second(s), 18 queries .
