查看: 13|回复: 0
welding carburized steel ?
发表于 2021-9-1 00:46:39 | 显示全部楼层 |阅读模式
I have some broken 1" carburized rock  drill steel  that I want to cut the shank of and weld a custom U shaped end on it to mount on my air hammer to drive steel plate intto the ground. Can this type of work possible? what type of rod? does it need to be heat treated again after the welding? preheat post heat? This is just for one job i have to drive 2 steel plates so it does not have to last very long.
Reply:Here is a pic of what I want to do. Still have some more prep work to do. Sorry for the bad pics from my Iphone and it was kind of dark. Attached Images
Reply:Here are the pics all welded up. Attached Images
GMT+8, 2025-12-21 12:00 , Processed in 0.117726 second(s), 18 queries .
