Lincoln Ranger 8 ?
发表于 2021-9-1 00:46:39 | 显示全部楼层 |阅读模式
Ihave a Lincoln Ranger 8 with a 16 horse Onan Performer. The questing I have is will it hurt my welder to put a car battery on it instead of the lawn mower type?Martin MC Weld TechAWS-CWIAWS-CWEwww.linkedin.com/pub/martin-cramer/20/b36/940/
Reply:I would think any battery with the proper voltage and enough cranking amps to do the job, with the cables connected in the correct polarity, that will also physically fit wherever it is you intend to keep it, should do the trick.  The machine doesn't know what kind of battery it's connected to, it only reacts to what voltage, current and polarity is being supplied when you hit 'start'.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I have been using car batteries on my weldanpower 225 for years, no issued , always starts well."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by kolotI have been using car batteries on my weldanpower 225 for years, no issued , always starts well.
Reply:I have a ranger 8. Mine has a tractor battery in it but any 12v battery will work fine as long as it fits.Lincoln Ranger 8Lincoln 140c MigLincoln Tombstone(doesn't everybody have one ?)Miller 200Diesel/Heavy Equipment MechanicLead Plant Mechanic Municipal Water
GMT+8, 2025-12-21 11:59 , Processed in 0.092869 second(s), 18 queries .
