Lincoln Easy-Mig 180 with Magnum 100SG spool gun ?
发表于 2021-9-1 00:46:32 | 显示全部楼层 |阅读模式
How would this setup work for metal up to 3/8" and for thinner Aluminum ?Almost all of my beads will be quite small and much of the welding will be simple tack welds.... I was curious if anyone else has the same or has used a similar setup ?What typically can one weld in Aluminum with such a spool gun ?  I am also very curious about how the aluminum spool gun compares with a 'mid line' TIG machine ?Cheers,/Jman...
Reply:Only Mid line Tig with AC would be a Miller Diversion 165- about 1,300.00Here is a thread on the Lincoln Spool Gunhttp://weldingweb.com/vbb/showthread.php...coln+spool+gunbut note he has the Power Mig CEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1Only Mid line Tig with AC would be a Miller Diversion 165- about 1,300.00Here is a thread on the Lincoln Spool Gunhttp://weldingweb.com/vbb/showthread.php...coln+spool+gunbut note he has the Power Mig C
Reply:Only model that is Continuous Voltage selection is the C modelPower Mig 140CPower Mig 180CALL other models are Tapped Voltage sectionSP 180tMigPakEasy MigetcEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1Only model that is Continuous Voltage selection is the C modelPower Mig 140CPower Mig 180CALL other models are Tapped Voltage sectionSP 180tMigPakEasy Migetc
Reply:It comes down to $$ and how thick you need to goEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Well,Thickness isn't really an issue for the stuff I do.  I would like to do some thicker Aluminum but most of that would be tacked into place as NONE of it would be load bearing or stressed in any way as it would be mostly ornamental / Artwork.I see that Miller has a new unit out called the "Diversion 165".  I found some decent pricing around the city and thought it might be perfect for what I need it for....Most of my stuff:20 gauge to 3/16" steel sheet / plate20 gauge to 1/8" Aluminum22 gauge to 1/8" Copper and Brass / BronzeSquare and round stock in both copper, stainless and mild steelCheers,/Jman...
Reply:Originally Posted by jmanWell,Thickness isn't really an issue for the stuff I do.  I would like to do some thicker Aluminum but most of that would be tacked into place as NONE of it would be load bearing or stressed in any way as it would be mostly ornamental / Artwork.I see that Miller has a new unit out called the "Diversion 165".  I found some decent pricing around the city and thought it might be perfect for what I need it for....Most of my stuff:20 gauge to 3/16" steel sheet / plate20 gauge to 1/8" Aluminum22 gauge to 1/8" Copper and Brass / BronzeSquare and round stock in both copper, stainless and mild steelCheers,/Jman...
GMT+8, 2025-12-20 17:20 , Processed in 0.092766 second(s), 18 queries .
