Small Job - Futon
发表于 2021-9-1 00:46:20 | 显示全部楼层 |阅读模式
http://www.walmart.com/catalog/produ...74371228699528The legs on this futon recently broke off.  Anyways, I was wondering if it would be possible to weld this back together.  Thanks.
Reply:Yes.The only concern is that the Silver finish on the Frame will be a little tough to match.If the welds are in a spot where they will not be seen then just some Silver touch up paint and yer good.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Did the welds break or tear from surrounding metal?  Could need some extra bracing
Reply:Lotta people don't sit down, they fall down. That's tuff on furniture.
GMT+8, 2025-12-20 17:19 , Processed in 0.255277 second(s), 18 queries .
