Inverter Welding Machines
发表于 2021-9-1 00:46:20 | 显示全部楼层 |阅读模式
I am a graduate student in Croatia and I just got assigment from my profesor to write him an seminar concerning Inverter welding machines on 20 pages.I tried googleing for literature but couldn't find anything useful.I need help in finding some literature concerning inverters either articles or books.Please post me if you know anything
Reply:konjic,Can you give the specifics of what kind of information that you are looking for?Do you need to be able to identify key differences in inverters /choppers/transformers?Do you need to describe how it works?Do you need to describe the variations of different inverters?Do you need to know how it transforms the current?(wave form)Do you need to know what kind of application it is to be used for?Can you specify?  There's quite a lot of info to sift through.  I would suggest going by your LWS and picking up product catalogs from Lincoln, Miller, ESAB, etc...There is a lot of "practical" info that can be gleaned from them concerning the advantages of their particular inverter based machines....Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I need theory how it works, how it transforms current, what are advantages and limitations of inverters and i need to write 20pages about that
Reply:http://www.millerwelds.com/resources/basicelec/Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by broccoli1http://www.millerwelds.com/resources/basicelec/
Reply:Lincoln Electric has an excellent DVD that starts things out for the layman.."Introduction to Inverter Technology".The whole basis is that there are massive savings in the weight of a transformer when you increase the frequency from 60 cycles per second to tens of thousands of cycles per second.  A transformer that weighed  36 KG  in an older welding machine now only weighs less than 5 KG  in an inverter based power source.  The numbers I use are approximate... some claim as much as ten to one saving.
Reply:Thanks lotechman I found basics all around but all I find are basics. And they are all saying the same thing. I need to expand it as I was given to write 20 pages on Inverters and I am having trouble finding any literature on them.
Reply:Do you want someone to write it for you then!Keep googling and searching threads, the more YOU read and research the more you will understand about the subject  that you have been given to do.You should have no problems obtaining  20 pages to write aboutCheersBilly
Reply:Kon,If you will look at the Chinese forums,  they are dealing with the issue of Mofset vs. IGBT technology in the inverters.  You might want to discuss that aspect of inverter design and issues regarding each configuration of inverters and the charachteristics of each. Deal with the thermal issue vs. reliability vs.  old style transformers.  But,  in each of the questions, I gave you earlier,  you could easily put together a couple of pages each out of those topicEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Thanks Lugweld you were helpfulI found some materials but most of those are from forums and from manufacturors catalogs. I couldn't find any article written about subject. I don't know how much material i got. But i know that when I look at the references I have it is pretty thin. I can't write forum threads as references. Only articles and books are allowed. And I could't find much I've got some articles from Welding, some articles from AWS Welding Journal. But because subject of these articles are overlapping I need to find more.
Reply:konjic,Take a look at the IEEE database of published research for info on the durability of MOSFETs vs. IGBT technologies.  You probably will not find articles specificly about inverter welding power supplies, but I'm confident that you could find some general research on the subject.  Use the info in the forums for Everlast, etc. to find out what chips or components are used in their products and look for generic info in the IEEE database for research on those pieces.IEEE database may be reachable online; or I imagine your university library has access to it.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:20 pagesEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I did some looking around on this subject last summer trying to create a simple few paragraphs explaining inverters.  I found these sites from Lincoln:http://www.lincolnelectric.com/knowl...t/inverter.asphttp://www.lincolnelectric.com/knowl...nt/chopper.asphttp://www.lincolnelectric.com/knowl...efficiency.aspI also found some graphics from the inverter manuals.  Every manual for every machine Lincoln makes is online.  For the life of me I cannot remember the exact location of the diagram.  Not sure if it is readable Attached Filesinverter diagram,linc.doc (42.0 KB, 32 views)Last edited by lotechman; 04-15-2009 at 02:42 PM.
Reply:Thanks lotechman this was very helpful.Thanks once more
Reply:Will the pros and cons of using inverter welding machines be part of your research? Based on my experience, here are some of them:PositivesCan weld on lower amp requirements.Efficient use of available current - no heat lossLight weight great for maintenance peopleNegatives:Expensive to purchaseExpensive to repairThe squealing noise made during weldingMidwest Metal ProductsMetal Wire Forming Fan Guards Delta-Larm
GMT+8, 2025-12-20 17:21 , Processed in 0.090730 second(s), 18 queries .
