1/8 steel and 3/16 steel and the Lincoln Electric Handy MIG Welder
发表于 2021-9-1 00:46:12 | 显示全部楼层 |阅读模式
Folks I'm considering the purchase of the Lincoln Electric Handy MIG Welder. My hobbyis is to design and fabricate steel ornament work with 1/8 and 3/16 steel.  My 2 questions are,. the LE Handy Mig welder is spec out to weld up 1/8 steel,..I have a 1/8 thick by 2" wide and 24 inches long steel curved in the shape of an "S".    I want to weld this "S" shape steel standing on the surface of 3/16 thick steel plate (10x30x3/16), though this mig welder is spec for "up to 1/8 steel", will I be able to accomplish the weld with this mig welder? I plan on only using flux wire in all my current and future welds,.. will I get enough power from the LE Handy Mig using flux wire to accomplish this?I was also considering the Hobart Handler 125 (which can weld steel up to 3/16 thick) from online, but would like to stay with Lincoln Electric only because I can gets parts easily and quickly at Home Depot, Lowes and Sears.  And I haven't found a Home Depot, Lowes or Sear to stock Hobart parts. And I have considered the Lincoln Electric 125, but the price is too expensive for me.Thanks everyone.Last edited by Alec217; 04-19-2009 at 06:53 PM.
Reply:Isn't the Lincoln Handy Mig a 100 amp machine?  I don't know, mine are 220 Volt.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Mark, the Lincoln Electric Handy MIG Welder is actually a 115volt setup and 35-88amps.
Reply:Alec,The HH 125EZ gets really good reviews. Buy a few spare tips and yer good to go.http://www.hobartwelders.com/weldtal...ighlight=125ezread Rocky D's post and then search out his profile and other posts on welding.I wouldn't worry too much about being limited to On-Line for supplies.You can get the wire at HD, Lowes- and that is usually what you run out of anyway.Heck, buy the Lincoln and try it, don't like it return it.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-20 18:44 , Processed in 0.095984 second(s), 18 queries .
