Nuclear clearance how does one get this?
发表于 2021-9-1 00:46:09 | 显示全部楼层 |阅读模式
I was just turned down for a job due to not haveing clearance already....how does a person go about getting this clearance so next time I am good to go?If it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
Reply:Originally Posted by ddogI was just turned down for a job due to not haveing clearance already....how does a person go about getting this clearance so next time I am good to go?
Reply:We have the WIPP (waste isolation pilot plant) here in Carlsbad, NM. While I'm not understanding the type of clearance needed at whatever facility you were turned down at, I'm assuming it is a security thing? A thorough background and security clearance to work in a government controlled environment dealing with nuclear reactor, waste, etc.? The facility that refused you clearance should be able to tell you where to go and what is required. The SS welding program here at the University requires a weld made with the nuclear code for SS be documented a minimum of every six months in order to keep your certification for the proceedure. In order to receive certification in the first place requires passing a program taught at the university learning the proceedures used to produce, repair equipment used at the LOCAL facility. Other than that, I can't answer your question. This is dated, too, as I haven't been involved with it for several years now.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Do you mean clearance or certification?  Usually, the government pays for the clearance investigations.  It takes at least 3 months if you have been living clean.  If you have any drug history you might have to say forget it.  If you have a lot of traffic tickets, it can take a year of so to get one.  They used to cost as much as $85K for some people.  They are required at some defense contractors who deal in navy nuke stuff.  There are two levels of clearance  DOE "L" (confidential) and DOE "Q" (secret).  The government probably won't let someone apply until they have a specific job offer in hand.  Since people don't want to sit around and wait to start a new job, many companies now try to hire people who have existing clearances.  I had on once when I worked on navy nuke weldiing processes.  The people who hired me brought me in uncleared and paid me to basically do nothing until I got my clearance, and it took me 3 months to get cleared.  A good way to get one otherwise would be to join the navy and work as a reactor repair weldor. Then when you exit the navy would would be qualified for civillian DOE cleared jobs.
Reply:Somebody's jerking your chain. You don't go get your own background check the employer does. At least that's the way it's done at the nuclear plants of my employer. MikeD74T
Reply:I've worked as an apprentice at WSI (Welding Services Inc.) and they take care of it for you. Expect MUCH paperwork.
Reply:Originally Posted by MikeD74TSomebody's jerking your chain. You don't go get your own background check the employer does. At least that's the way it's done at the nuclear plants of my employer. MikeD74T
Reply:what happened was I didn't have security clearance for nuclear plants.They gave the job to guys that did already have security clearnce.I have had clearance at navy ship yards and have worked at plants that built military items, I just have never worked in a nuke plant"yet" and the guy that was doing the hireing said that if there was more time for all the background checks to get done then that would be something differant. he did say he was going to keep in touch and see what he can do to help but I was hoping to try and do it on my own so I didn't run into this issue again.If it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
Reply:Usually they hire guys who have been badged within the last 12 months first.  If they need more guys then they will bring in new guys.  It's all about saving time and money on background checks.  I've been working nukes for over a year now and on my first one it took about two weeks to get badged and pass all the NANTEL stuff to get in.  Just got back on an outage last month and since I held a badge within the last 12 months it only took me 2 days to get back in the plant.
Reply:You can't do/have the check done on your own. A rule to get the "red badge" which is unescorted access, is that you have to have a legitimate reason to be in the plant. Normally when you are hired on, they (plant owner) run you throught the background check, psychological testing, piss test and all the training you have to go through. If you are going in as a contractor same applies and yes for cost reasons the would likely go with some one who is already red badged. Perhaps you could talk to your contact in the plant and ask to do a short duration job under a "yellow badge" this would require that you are escorted at all times inside the protected area of the plant. But it could help get your foot in the door maybe.Thinking about it alittle more another option would to be to try to get on during a big outage at the Nuke. Usually the company will gear-up to run alot of people through the paces to get them there clearance.Last edited by dakook; 04-19-2009 at 01:25 AM.
Reply:ddog, You may not want to hear this but the majority of temp craft workers that come into our nuclear power plant are brought in via union affiliations. They are members of the reigning local, travelers, or have a "permit" for a single job.  Clearance applications start at the union hall. Security checks can easily take 3 months. Others come as vendor employees. My personal opinion is that this is less about your trustworthyness than about maintaining a huge bureaucracy -Homeland Security. Short story - I was called at home by a clearance company & requested to feed info about a vendors employee to a third party so the clearance company could call the third party back for the info. When I reported this to my employee alligations group the vendor withdrew it's clearance request & their employee was terminated. This employee would have passed any legitimate clearance challange but the vendor didn't want to make waves ??? I find the NRC to be equally not credible.We've even had long term employees that through administrative mistakes had their badge pulled & it took a month to get them back into the plant. Any badged employee or vendor must enter the "protected area" at once every 30 days or their access is suspended. .  If they want you to work for them they'll provide the clearance, keep trying.  MikeD74T
Reply:Originally Posted by MikeD74TIf they want you to work for them they'll provide the clearance, keep trying.  MikeD74T
Reply:I just recently got L cleared, it takes about three months. Most nuke plants tend to hire people that are already cleared, if they have that option. As Mike and Gary said though, keep poking around though, once you get your foot in the door you can move around to different trades in the plant.Shake and Bake
GMT+8, 2025-12-20 18:45 , Processed in 0.092112 second(s), 18 queries .
