Can u weld
发表于 2021-9-1 00:45:59 | 显示全部楼层 |阅读模式
Just picked up the Hobart 235 V AC/160 V DC Stick Welder and it didnt come with wheels so i wanted to well round stock on the back of it and put wheels i already have on there instead of purchasing their wheel kit..Can i weld right on the welder or will this harm something ?
Reply:While it would probably work like your talking about doing it, build a frame with angle iron to set the machine in, and put the axle and wheels on it. Unless you take the machine apart enough to confirm that nothing inside would burn up, I wouldn't weld to the machine itself. Old bed frames are made from a light weight angle, and there is enough of it to build the frame and a handle to move it around with. If you have round stock too, build the frame and handle with places to roll up your leads, too. Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:THanks Gizzard... have to say though i thought with all the pro-welders on here more would have knowledge on this area.. guess i was wrong
Reply:Build one of these............ Attached ImagesMarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:ive welded on several generator welders when the wheels broke off the front of it the miller bobcats are the worlds worse  but then again they were rentals not mineComplete Fabrication Shop specializing in pipe fabrication. Also offering heavy steel fabrication and sheet metal work.
Reply:Originally Posted by MarkBall2Build one of these............
Reply:You could weld tabs on your axles that screw to the welder if you want to save weight by stressing the welder box. I'm assuming the lower edge is turned down so you can drill it without the risk of hitting vitals. If you burn up the paint inside the welder the smoke will leave residue everywhere, plus those spots inside will be susceptible to rust unless you open it up and clean/paint it.Lincoln SA200, HH135, Lencospot, HF80 Inverter, Rockwell 11x35 lathe, HF drill mill, Kama 554 tractor w/ FEL & BH, Belarus 250AS, lot's of Chinese tools
Reply:Try this one............ Attached ImagesMarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Originally Posted by HvPhotogTHanks Gizzard... have to say though i thought with all the pro-welders on here more would have knowledge on this area.. guess i was wrong
Reply:Like thishttp://www.hobartwelders.com/images/...C-wRunGear.jpgLincoln SA200, HH135, Lencospot, HF80 Inverter, Rockwell 11x35 lathe, HF drill mill, Kama 554 tractor w/ FEL & BH, Belarus 250AS, lot's of Chinese tools
Reply:welding the welder?  isn't that gonna cause a fracture in the space-time-continuum?  kinda like chicken going back in time to peck at the egg he was hatched from?  I'd consult Q
Reply:Got it.. not welding on the welder.. drilled larger holes through for larger axle and larger wheels.. all done :-) ... lol
Reply:Originally Posted by oxy moronwelding the welder?  isn't that gonna cause a fracture in the space-time-continuum?  kinda like chicken going back in time to peck at the egg he was hatched from?  I'd consult Q
Reply:My Stickmate is sitting on a $9 HF mechanics creeper that I shortened and moved a set of outboard casters into the middle.  In front there is a 2 foot high cable holder made from the legs off an ironing board and a Christmas tree stand.  Low center of gravity and fits under work bench.TeddCoHTP Microcut 400 & Invertig 160DC  Smith Dual Guard MD-510 OA Rig  Lincoln SP135+  Hobart Stickmate LX 235/160
GMT+8, 2025-12-20 17:20 , Processed in 0.072858 second(s), 18 queries .
