How to remove hot gal?
发表于 2021-9-1 00:45:59 | 显示全部楼层 |阅读模式
I need to remove some excess hot gal from the inside of some 73mm tube with a plate a one end.  They are 300mm long.  I cant get a bur for my die grinder with a long enough shaft.  I tryed a cold chisel but cant get a close enough finnish.Any suggestions.i was thinking of heat direct with O/A torch and weld tip but dont want to damage the outside too much.
Reply:I assume you only want to remove excess material which sticks up, otherwise you could use acid or electrolysis. Weld a nut on a piece of running thread, find a piece of cylindrical rubber and drill it to allow the running thread to go through, use washers and a second nut to tighten the rubber in place. If you can find sanding sleeves to fit the rubber, expand the rubber by tightening the nut enough. Otherwise, cut a strip of sandpaper whose width is the length of the rubber plus a bit more, and tape it on the outside of the rubber so the unit can be driven by a high speed drill. Make the strip long enough to go around a few times, so you can trim the worn material away without replacing the whole strip at the same time.Last edited by Oldiron2; 04-28-2009 at 01:50 AM.
Reply:That sounds good.  With some good 36 or 80 paper.
Reply:Disappointed   I read "Hot Gal" and I was wondering why anyone would want to remove her.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Would never like to remove your hot gal...She's nice
Reply:Originally Posted by littlefuzzDisappointed   I read "Hot Gal" and I was wondering why anyone would want to remove her.
Reply:LarryO,Please send photos of the hot gal you'd like removed.Might be worth a trip to Australia.  Know you guys had some nice ladies down there in the late 60's-early 70's.  One of the favorite R&R spots for the guys in VN.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:id agree with oldiron. but my original thought to seeing the post before i read it was just call her by her sisters name while you were in the middle of extra "recreational" activity.If you like my stuff you can find me on Facebook.  https://www.facebook.com/theangryanv...ngryanvilforge
GMT+8, 2025-12-20 17:20 , Processed in 0.087700 second(s), 18 queries .
