steel weights
发表于 2021-9-1 00:45:54 | 显示全部楼层 |阅读模式
Where can I find some good charts on various steel weights per foot or lineal foot?
Reply:Go here and see what this free metal weight calculator is like. I downloaded a freeby from them some years ago and it's pretty handy. This one is probably the same one ?? http://www.suppliersonline.com/Default.aspAbout 3/4's of the way down on the page.
Reply:if you take the thickness of steel multiply it by the width of steel then multiply that by the length of steel then multiply that by .2833 you will get the weight of a steel object. steel weighs .2833 per square inch. so if you had a 1/2" by 12" by 14" piece of steel your formula would look like this .50 x 12 x 14 x .2833 = 23.7972 lbs. if you have an object that is 5 foot long, your length would be 60" you have to put it in inches. has always worked well for me.
Reply:per cubic inch sorry. im goin to bed!
Reply:There's a 'sticky' at the top of the MIG, TIG, Stick section. Post 6 has a chart.http://weldingweb.com/vbb/showthread.php?t=29419-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:http://bushwickmetals.thomaswebs.net/formulas.html - You can find formulas here to calculate the nominal weights for various steel shapes. Weight calculations are based upon the theoretical weight of steel at 40.80 pounds per square foot per one inch of thickness. Check it out.Midwest Metal ProductsMetal Wire Forming Fan Guards Delta-Larm
GMT+8, 2025-12-20 19:06 , Processed in 0.089411 second(s), 18 queries .
