Learn't how important earthing is today !
发表于 2021-9-1 00:45:48 | 显示全部楼层 |阅读模式
It's only taken about 2 months, but finally worked out why some of my welds were not behaving like others.All my welding with my MIG, I have just clamped my lead earth wire from my mig to the leg of my work bench. 75% of the time it all works nicely, but sometimes the weld spits and farts and carries on.Today I discovered that if I clamp directly to my work piece all these problems go away and the welds are a work of art (sort of).Never realized how important it was till now.
Reply:Even better if you can clean the area you clamp to.  You need good contact.
Reply:Clean grounding clamp area is Very Important. I also find that have the grounding clamp close to the welding area also gives a clean consistent weld.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Use a C-Clamp, F-Clamp, Vise Grips etc on the material if the Work clamp can not open enough to attach to the Project materialEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1Use a C-Clamp, F-Clamp, Vise Grips etc on the material if the Work clamp can not open enough to attach to the Project material
Reply:Good lesson.  Also, remember keep the current from gong across hinges and bearings--ground and weld on the same side of the bearing.
GMT+8, 2025-12-20 20:33 , Processed in 0.235195 second(s), 19 queries .
