LA-MAN Water Extractors
发表于 2021-9-1 00:45:41 | 显示全部楼层 |阅读模式
Anyone use a LA-MAN (520A) water extractor on their air supply system? Specifically looking to use one on the back of my Cutmaster 38.I am also replacing my whole house/shop filter with a Motorguard M30, so I will have the M30, then about 35ft of air line, then the La-Man. Reason for both filters is that by the time air flows thru the big one and the air gets all the way to the hose end, it will have created a little bit of moisture.I would imagine this set up will work good enough, no?http://www.laman.com/extractor.htm
GMT+8, 2025-12-20 20:32 , Processed in 0.158850 second(s), 18 queries .
