Metal Storage Shelf
发表于 2021-9-1 00:45:39 | 显示全部楼层 |阅读模式
I've been welding for about year and a half now and have turned into the biggest metal pack rat, anything weldable I keep it. Problem is I have it all piled up in a big cardboard box that is about to explode. And like everybody else garage space is at a premium, so how do you guys store your metal I am looking for ideas.Thanks
Reply:http://images.google.com/images?hl=e...gbv=2&aq=f&oq=here is one from herehttp://weldingweb.com/vbb/showthread.php...=material+rackEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1http://images.google.com/images?hl=e...gbv=2&aq=f&oq=here is one from herehttp://weldingweb.com/vbb/showthread.php...=material+rack
Reply:That's the one I liked too. I will probably use angle off an old bed frame instead, I got it laying around.
Reply:Here is a link to my post showing my storage rack:  http://weldingweb.com/vbb/showthread.php?t=23845It really holds a lot of steel, is easy to sort, pick and pull. I used heavy duty carpet cores, but you can find something similar or use PVC pipe.Having various lengths of tube is actually pretty handy, put short pieces in the shorter tubes so you can still find it.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:heres a few i madeDaye Attached Images
GMT+8, 2025-12-20 17:51 , Processed in 0.096364 second(s), 18 queries .
