Nooks & Crannies & Grinding, oh my!
发表于 2021-9-1 00:45:38 | 显示全部楼层 |阅读模式
Howdy Folks, I'm building a metal rolling ball sculpture and have a need to get into those small places to do some surface grinding for that "brushed" look and to get rid of the paint, etc on the old metal I am using. Naturally my grinder with a flap disk is too big to reach into those nooks and crannies. Is there a tool or method out there that will let you reach these tight spaces?-dennis -- Beekeeper with a Welder --
Reply:For something like the RB Sculture a Dremel would workhttp://www.dremel.com/Pages/default.aspxEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I'm looking to get that grained surface finish look rather than grinding weld joints per se. I have a Dremel with many bits but none that would "brush" the metal surface and get it to look like the larger areas I've already gone over with the flap disk, if you know what I mean...-dennis -- Beekeeper with a Welder --
Reply:Thin sanding belt cut to make a sanding striphttp://www.use-enco.com/CGI/INPDFF?PMPAGE=259&PMCTLG=00Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1Thin sanding belt cut to make a sanding striphttp://www.use-enco.com/CGI/INPDFF?PMPAGE=259&PMCTLG=00
Reply:Google 'string abrasive' or 'abrasive cord'. 9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
GMT+8, 2025-12-20 17:42 , Processed in 0.126841 second(s), 18 queries .
