Does anyone know this is
发表于 2021-9-1 00:45:34 | 显示全部楼层 |阅读模式
I've got this Lincoln welder it has a 16 hp Briggs&Stratton engine on it .I've had it about 15 years
Reply:What specifically do you need to know about it plandon?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:The age,model.The face plate has been changed,I think its a Ranger but not sure which one
Reply:If the face plate has chancsd it must have been a direct replace item. It looks like a weldanpower to me. I may be wrong becuase its been 23 years since I've used one. They were ok welders for their day and if they're running fine and have enough aux power for you keep using it til she blows. The one i used didn't have such a great muffler, they really barked.Tough as nails and damn near as smart
Reply:It's not a Ranger.  The Ranger line had not come out yet when that one was made. I believe the face plate is original.  If not then it was a replacement as it is the same as the original would have been.  Go to the Lincoln website, and run the serial and code number and you can find out most anything you want to know about it.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:There are no serial#s or codes on the face plate.Oh well she runs great and welds good for what I do.(mostly ranch work) I still got the SA200 when I get her running for everthing else.Thanks guys
Reply:The Weldanpower is a fine welder.The city bus sized muffler makes me thinks that someone has already visited the noise issue. If the face plate has been changed, you could check to see if there's an extra "click" for CV mode, other than that I can't think of any reason to worry about the plate.If the machine ever sees rain, you should seal the gap around the lifting strap; originally that had a rubber boot around it.The fence posts are sure lined up purdy. Are the posts your work Plandon?Good LuckLast edited by denrep; 05-18-2009 at 10:20 AM.
Reply:Yes,I used a transit to line them up and to cut them off,works pretty good.ThanksI was thinking about selling the Weldanpower,but don't know what its worth.I guess what the market will bear.
Reply:In the upper left of that particular unit there should be model # and the serial#. Then go to the Lincoln web page and run the numbers. The only way there wouldn't be any numbers on that face place is if the original was damaged and they replaced it.Take a close up picture of that upper left portion of the front face plate. If there are any numbers I can run them and give you the info.Tomadd on I tried to blow up the picture looked like there might be some number but I could not make them out. What specific info are you looking for on that unit? If you go to the Lincoln site and post a picture to the forum somebody should be able to help you.Last edited by specter; 05-18-2009 at 01:43 PM.Reason: add onCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:plandon - I've seen them advertised in the $800-1400 range for running units like yours but don't know what the sellers actually got for them.  Obviously less if not running, welding or producing power.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:http://www.flickr.com/photos/weldersales/2172292546/There is a Weldersales  member here- you could PM himEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:It looks like a Lincoln G9 Pro (almost).On the middle right of the panel you have and extra switch.So maybe yours is Pro Pro. It's a start on you getting more info.  I have a neighbor that has one in the next series and he loves it.
GMT+8, 2025-12-20 17:40 , Processed in 0.144040 second(s), 18 queries .
