I finally got a C25 cylinder. The regulator that came with welder has a barb fitting for the feed.Is this OK to use or will there be too much pressure? It seems to be a threaded connection would be better. Any have experience using the barb?Hobart Handler 187Bainbridge bandsawMakita chop sawHarbor Freight 4.5" grinder
Reply:The barb fitting is fine as long as you use some kind of hose clamp. Without a hose clamp the pressure may blow it off as you said,OAdoctorwww.regulatortorchrepair.com
Reply:Originally Posted by OAdoctorThe barb fitting is fine as long as you use some kind of hose clamp. Without a hose clamp the pressure may blow it off as you said, |
