Looking for a good supplier for Sucker Rod
发表于 2021-9-1 00:45:33 | 显示全部楼层 |阅读模式
Looking for a good supplier for sucker rod. Who do you guys use?? Where are they located??ThanksAaron
Reply:what is sucker rodComplete Fabrication Shop specializing in pipe fabrication. Also offering heavy steel fabrication and sheet metal work.
Reply:Try oilfield supply companies.  They usually have used sucker rod laying around.  I don't know what it's worth these days.  Used to be used a LOT for fencing and corrals."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by scubaholicwhat is sucker rod
Reply:Oh, and contact companies that operate pulling units, they might know of some for sale"Any day above ground is a good day"http://www.farmersamm.com/
Reply:You got it right Samm, That cable is called a "bridle". It hangs on the "horse's head". The horse's head is attached to the front of the "walking beam". Just some oil field terminology.  They are all magnatized after being used. Calls for 7018 and some cussin'. I really don't know where to buy any now unless some of the oil companies still sell them when they get too bad for downhole use.Last edited by Oldtimer; 04-27-2009 at 08:40 PM.
Reply:Around here in North Texas, you can purchase sucker rods from $6.00-$10.00 each (used), depending on diameter and how good they are. They come in 30' joints +/- a little, and usually in 1/2", 5/8", 3/4", and 7/8" diameters. I dont know how much oilfield business goes on up there, but oilfield pipe and supply places will have them. If a company plugged an old well, they leave them laying on the ground, sitting on blocks alot of the time. You might talk with a lease operator about selling some. Plain ol' round bar bought new is another option unless you really want sucker rod, and it wont be magnatized or pitted by salt water..............................."Look Good Doing It"!!!!!!!!!!!!!!!
Reply:I was going to mention that all used sucker rod will be magnetized and a biotch to weld, but Oldtimer already covered it a lot better than I could.Definitely will bring out the cussing and fussing.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:I have a truckload in Texas.  Maybe to far to ship.  Mine is 7/8" and 1" x 25'.I am asking 11 cents/lb.  That is equal to about $8 for the 1" and $6 for the 7/8"Keith   610-941-6000keith @ acclaimmetals.com
GMT+8, 2025-12-20 18:46 , Processed in 0.120763 second(s), 18 queries .
