Welding 1/2 inch Light Weight - Help
发表于 2021-9-1 00:45:32 | 显示全部楼层 |阅读模式
Hi - I'm welding 1/2 inch pipes- Can someone please advise what electrodes to use - and do I work top to bottom or visa versa....also not for water - and pipes are 1.5mm Thanks a millParweld XTI 140 / XTI 140DV MMA Inverter
Reply:Hard to say with out more information. Ferrous or non-ferrous?  What alloy? What grade? Is the wall1.5 mm? Not for portable water...lethal substance? steam.?
GMT+8, 2025-12-20 18:46 , Processed in 0.071411 second(s), 18 queries .
