Magnaflux?
发表于 2021-9-1 00:45:31 | 显示全部楼层 |阅读模式
Anyone know how magnaflux(magnetic partial) testing works? I know its suppose to pick up cracks but what about porosity? I was in a few bad positions not sure if ill have any..
Reply:Google is your friend...http://www.magnaflux.com/DocumentLibrary/MagneticParticleFAQs/tabid/187/Default.aspx
Reply:Sometime you forget the simplest places to look. Thanks
Reply:Parts being tested with dry iron powder must me degreased & given ample time for any cracks to dry of solvents.   It works by forming a magnetic field around the poles of the maganet.  The field is very much like the ripples on water after tossing in a stone.   A crack interrups this field & the powder will line itself up along the crack.If the parts in question are small & glass bead cleaning is ok.   First clean the parts in a solvent like in a parts washer tank.  If clean run the solvent over them anyway.   Glass bead clean, lay parts out handling them with nitrile gloves,   If there is even a tiny crack the solvent will wick back out of the crack & form a drak gray or black looking line.   Up sid of this is it works on Al. as well as ferrous metal.IF IT WORKS, DON'T FIX IT2 Lincoln CV-300 / LN-7 GMALinde-VI 253,400 & 450 w/MIG35 feedersCNC Table with Oxweld O/A & Hypertherm 1250G3Lincoln Ranger GXT 250Hobart-MicroWire 300ESAB Heliarc 161ESAB-Mobilemaster 2 CC/CV Feeders& more
GMT+8, 2025-12-20 18:51 , Processed in 0.090435 second(s), 18 queries .
