Wiring up dynasty 200dx one phase?
发表于 2021-9-1 00:45:29 | 显示全部楼层 |阅读模式
Hi.I am new in welding  and now i have dynasty200dx.I do understand how to wired it up to three phases but not sure about one phase.There is phase,negative and ground in a socket,so green/yellow-ground,black- phase,white-negative,red-not use?If i am wrong then how its should be?Sorry for my english,i hope somebody understands my problem.
Reply:Originally Posted by 7A749Did you get an owner's manual with your machine? On an XMT series inverter, red is not used for single phase operation. According to the tech manual for Dynasty 200 machines, it is the same. Red is NOT used for 1 phase operation. Only black & white for hot, green/yellow for ground. www.millerwelds.com will provide you with an answer if you want to see for yourself. Simply look up your machine & download a free copy of the owner's manual.
Reply:Where are you?Anyhoo- Like this for North AmericaEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1Where are you?Anyhoo- Like this for North America
GMT+8, 2025-12-20 18:47 , Processed in 0.091529 second(s), 18 queries .
