Old Airco Wasp III-E
发表于 2021-9-1 00:45:29 | 显示全部楼层 |阅读模式
While searching for manuals and wiring diagrams for my machine I came across this site and was excited to see someone else back in Nov. of 2007 had the same questions. He got the info he needed and said he was able to repair his machine and it works great. Hope someone here can do the same for me. I purchased the machine at an auction and am currently trying to clean it up and make everything work. I was able to get the machine started, but did not try anything but the generator which did not work. I am now tearing it down to clean up the carberator and look inside the cover to see if maybe my wiring diagram is still in tact. I'll be checking back in later to see if anyones got some info on this. Until then.......James
Reply:This site is full of competant people who can help you out.  Duaneb55 is always up for a challange restoring older equipment.  Post some pictures.  Good luck!Millermatic 252"Don't worry, he's got a welder, he can fix anything"
Reply:Thanks Sparkyman65, I do have some pictures I'll put on the original thread is I can figure out how.....James
GMT+8, 2025-12-20 18:51 , Processed in 0.096565 second(s), 18 queries .
