Need To Cut Thick Steel
发表于 2021-9-1 00:45:28 | 显示全部楼层 |阅读模式
I've never welded before, but I suddenly have a need to. My grandfather has these two semi trailers he wants gone so I'm going to cut them up and take the steel to the scrap yard. I've been looking around online for what the best type of fuel and equipment would be, but I thought asking a real welder was better than blindly roaming websites. Some parts of the frame are around 5 inches thick or so. The walls and roofs are thin aluminum with wood on the inside, but I already removed the wood. Also, I was planning on taking welding courses this summer so I could learn how to weld things for my car ( roll cage intercooler piping, exhaust, etc...) I was then going to buy a welding setup suitable for these tasks. If you guys could reccomend some equipment and a fuel that would be good for both I would really appreciate it. If you guys have some specific brands or kits to reccomend that would also be useful. I'm trying not to spend more than like $400 bucks, but I can stretch if I have to. Thanks.
Reply:Take the welding course.  Too many questions for an internet forum to answer properly.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:If you were to ask me, I'ld say learn oxy-fuel cutting.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:sounds like you're trying to keep costs down so you're probably better off going with oxy/acetylene and a good cutting  and welding torch.  If you go to plasma it's going to cost no less than 600, probably more for a unit that would cut over 1/2 inch material.  Multipurpose units cost over 1000 to start and then cutting over 1/2 inch isn't that easy.oxy/acetylene is a great tool; oxy/propane is used for high volume cutting since it's cheaper fuel but overal acetylene is better.  If you have lots to cut you might be better off leasing large tanks to start and keep looking for a deal on owner bottles since they are costly as well.  You will be better off taking some courses where you can see/learn what is available and get some good local guidance.  cutting takes some good initial instruction, then some practice.  it's hard to start out onyour own without someone showing you the settings and getting the 'sound' right for the torch on thick clean cuts.jbman45Century 230A AC/DCLongevity 200 Multifunction MofsetLongevity 200PI Multifunction IGBTVictor Oxy/Weld&Cut5HP 2 stage compressorTractor; tools and 40  years of collecting fine tools.
Reply:your not going to cut aluminum or stainless with oxy/acet.Go hot, or go home!
Reply:I have demo'ed these trailers before.Get Oxy/Acey and a good angle grinder.Grind the rivets off from the outside and take the exterior aluminum off in complete pieces.Do the roof first, then the sides.Then remove all the wood starting high and working your way down. Once ALL the wood is gone start cutting with the torch. With two helpers I have Demo'ed three of these in one day.Get a sawsall and cut the tires off the rims.Cut the axles into small pieces so you can move them. Throw it all in a big truck and head for the scrap yard.Bob
Reply:Well if you have never used a torch before and do not have any welding skills and need it gone right away contact a welder that can do it for you. There are safety issues  using any torch and if you have never used one I certainly wouldn't recommend you tackle this on your own. Offer them part of the scrap profits or any of the metal they might want. Aluminum sheets are hard to come by so they might want some of those.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:mp52026 ,Where are you? You could be close to me.Please post your location in your profile so we can all see where you are.Bob
Reply:Hi mp52026 to follow Bob's advice please go to the USER CP in the upper third of your screen, double left mouse click on it ands it will bring you to YOUR CONTROL PANEL and to your Control Panel. In the Control Panel you can enter your location and any member info you wish to share with other members. By posting you Location members will know where you are located. You'll find members here pretty helpful and maybe willing to help you with your problem of cutting up those trailers! Especially any member that might be looking for any metal you might be willing to part with.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Get a gas powered chop saw i use it alot on thick material blades are cheap. Also i would hire it out myself i have done tear downs of old tractors and we had access to a salvage torch. will go through like 6inches of steel we used propane cause you can run it longer also. We had several hundred gallon tanks that they ran off of
Reply:Originally Posted by jbman45sounds like you're trying to keep costs down so you're probably better off going with oxy/acetylene and a good cutting  and welding torch.  If you go to plasma it's going to cost no less than 600, probably more for a unit that would cut over 1/2 inch material.  Multipurpose units cost over 1000 to start and then cutting over 1/2 inch isn't that easy.oxy/acetylene is a great tool; oxy/propane is used for high volume cutting since it's cheaper fuel but overal acetylene is better.  If you have lots to cut you might be better off leasing large tanks to start and keep looking for a deal on owner bottles since they are costly as well.  You will be better off taking some courses where you can see/learn what is available and get some good local guidance.  cutting takes some good initial instruction, then some practice.  it's hard to start out onyour own without someone showing you the settings and getting the 'sound' right for the torch on thick clean cuts.
Reply:Why not just sell it?  The cheapest way to hack it up would be a good grinder.
GMT+8, 2025-12-20 18:47 , Processed in 0.092347 second(s), 18 queries .
