how far apart to space welds
发表于 2021-9-1 00:45:27 | 显示全部楼层 |阅读模式
i am currently building a welding table / workbench out of 1 1/2 in. sq. tubing 1/8 wall ,and the bench top is made of 3/16 in. plate i  was wandering how far apart should i run beads along the outside of the bench to attach the plate and how long should they be? and also should i weld the underneath side too?  thanks chris ..
Reply:That 3/16" top will be OK for a workbench but not much for clamping/tacking to as a welding table.  I know because that's what I have for mine and I've got my eye out for something at least 3/8" thick and preferably 1/2" to replace it.As for your 3/16", to avoid alot of warpage I would say 1/2-3/4" long every 9-12".  If everything looks good and you want to, you could come back and add more in between.  Perhaps others will have additional thoughts or suggestions.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:If you are going to make table you will use for years at least 1/2" steel plate, ask Duane how many times he wishes his table were heavier, 1/2" will still cup a little but you can set up a grid of drilled holes for clamping  and bending
Reply:should have used at least 1/2 " thick  the other stuff will cup really easy and after a while look like crap
GMT+8, 2025-12-20 20:22 , Processed in 0.099870 second(s), 18 queries .
