Snap-on Plastma cutter
发表于 2021-9-1 00:45:26 | 显示全部楼层 |阅读模式
It is a y-2240 that a friend is giving me.  I put a need tip, cone and all on the end but when I hook it up it will not cut.  If I touch the tip to the metal it will spark.  Any help would be great.  THANKS
Reply:Originally Posted by Kevin...It is a y-2240 that a friend is giving me.  I put a need tip, cone and all on the end but when I hook it up it will not cut.  If I touch the tip to the metal it will spark.  Any help would be great.  THANKS
Reply:Sounds like your friend already "let the smoke out".Good luck on getting support from Snap-On with that machine.  When it comes to electronic equipment I think they use the "sell and forget" policy.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Lets start with the obvious, you have the ground attached to the work piece? you did put a insulator between the electrode and tip right? you have air or nitrogen hooked to it right? the metal is not so rusty that it will not make a connection? always start with the basics
Reply:I had one of those.  You do need to push the tip against the work (its spring loaded) to get it to 'fire', then lift as you cut."Good Enough Never Is"MIller AC/DC  ThunderboltHobart HH180, 125EZRiland Cut 40 Plasma oxy/act  outfitTons of "stuff", all treasures to me!
Reply:If it's free It's usually for me.     However if you get it going & use it much. Once you start buying consumables you will wish it was a Hypertherm.IF IT WORKS, DON'T FIX IT2 Lincoln CV-300 / LN-7 GMALinde-VI 253,400 & 450 w/MIG35 feedersCNC Table with Oxweld O/A & Hypertherm 1250G3Lincoln Ranger GXT 250Hobart-MicroWire 300ESAB Heliarc 161ESAB-Mobilemaster 2 CC/CV Feeders& more
Reply:I put all new consumables in it with the air hooked up to it.  I will try it back out tomorrow and post back.  Thanks for the replys.
GMT+8, 2025-12-20 20:24 , Processed in 0.092948 second(s), 18 queries .
