Another Newbie - What kind of welder
发表于 2021-9-1 00:45:18 | 显示全部楼层 |阅读模式
I have been reading this forum for a while, avoiding doing some actual work.  I want to get into welding, but don't know where or how to start.  I want to weld/build some iron pieces for my house and add a firebox on my BBQ pit.  Specifically, I want to build a dining table with 2" square tubing and use an old cattle gate for the top.  I am considering a Lincoln wire fed welder from Home Depot, but I don't want to waste any money.  The flux cored welder seems to fit the bill fairly well and is not too expensive.  I don't think I will be welding anything over 1/4" plate.  Also, power is not a problem.Any advice? I don't want to break the bank on getting into the hobby.Also, how would I cut the tubing without buying a plasma cutter?
Reply:If I were you, I would go to your LWS and get a 110v mig machine, the LWS will have a higher quality mig, not the home depot version, run flux cored wire so you dont have to pay for gas. Get a portaband or a sawzall for cutting your material. Welding is not a cheap hobby to get into unless you want all crappy machines.
Reply:Thanks for the advice.  Will a 110v mig sufficiently weld 1/4 plate with flux cored wire?
Reply:buy a stick welder and an o-a torch
Reply:http://www.tractorsupply.com/webapp/...&Special=falseEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:The Home Depot and Tractor Supply and other 110v MIG welders are not the same as the one that the LWS sell.  If you are going to by a 110v MIG make sure it  has an fine tune control for wire feed speed.  All of the cheap one at the big box stores that I have seen have a stepped wire feed speed.  Also, the LWS machine will come with a gas solenoid (even if you start wth flux core) most of the cheaper ones do not.  Also, the drive motors are usually alot stronger.OAdoctorwww.regulatortorchrepair.com
Reply:The HH 125EZ is a Fluxcore only machine and they knocked it outta the ballpark on this one.http://www.hobartwelders.com/weldtal...ighlight=125ezhttp://www.hobartwelders.com/weldtal...ad.php?t=27599http://www.toolking.com/hobartwelders_500521a.aspxEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I don't understand why people think the Box store Lincolns are such a bad buy.Used a Lincoln Weldpak 100 and it welded just as good as the SP135+ that I purchased from my LWS.Heck a MM210 is a Tapped machine.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Is there a difference between a Lincoln SP 140 at a LWS shop and the Lincoln Pro Mig 140 available at HD/Lowes?  What about compared with a Miller Matic 140?  Is the Miller worth the additional $150?
Reply:Originally Posted by Tiger FishIs there a difference between a Lincoln SP 140 at a LWS shop and the Lincoln Pro Mig 140 available at HD/Lowes?  NO What about compared with a Miller Matic 140?  Is the Miller worth the additional $150?Different animal as it has Continuous Voltage selection rather than Tapped.
Reply:What do you mean Continuous Voltage versus Tapped?
Reply:"Tap output voltage control provides a range (usually 4-6 standard positions) of selectable voltage settings. Continuous output voltage control allows for infinite adjustment of the output voltage within the operating range of the machine, allowing more fine tuning and precise control of the welding arc." Source Lincoln Welding Like A ProCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
GMT+8, 2025-12-20 18:47 , Processed in 0.071600 second(s), 18 queries .
