HF Compact bender vs Shop Outfitters
发表于 2021-9-1 00:45:16 | 显示全部楼层 |阅读模式
Does anyone know if you can use the shop outfitters tube dies with the harbor freight compact bender?
Reply:Nope.Edit- was thinking about the ring roller.Not sure on the Dies for the bender.Last edited by Broccoli1; 06-04-2009 at 03:52 PM.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Arrrrrgh... I just wanna bend.. everything without the price!!! Sheesh! How hard should that be?? =P
Reply:bending tubing usually involves $$Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by feroxjb06Arrrrrgh... I just wanna bend.. everything without the price!!! Sheesh! How hard should that be?? =P
Reply:For tubing, buy a JD2. http://www.jd2.com/The shop outfitters is a joke- it now costs more, new, than a real hossfeld bender, that will bend rings around it. But neither shop outfitters, or hossfeld, is anywhere near as good as a JD2 for tubing and pipe.And they are really pretty reasonably priced- a new JD2 is only $300 right now, while a new shop outfitters, without tube dies, is $998.
Reply:I have a compact bender from northern tool. I bend 1/2" hydraulic lines. I sent the die I wanted to a machine shop and a sample of the tube. They cut a smooth goove in the die to fit the tube. It works good for slight bends, A 45 bend will still flatten the pipe a little. For what I needed it works good. If you do have someone groove your die, do it off to one side so you can still use the flat side if needed. Northern tool's bender is around 100 $
Reply:Wow.. that JD2 bender looks pretty sweet.  I think that's what I'm going to get! Thanks for the info!!
Reply:What I find interesting is... I believe the software for the JD2 bender that tricktools.com is charging $69 for.. is free on the JD2 website.Unless it's different..how sneaky!
GMT+8, 2025-12-20 18:44 , Processed in 0.093048 second(s), 18 queries .
