MM200 making sparks.
发表于 2021-9-1 00:45:15 | 显示全部楼层 |阅读模式
NOOOO!  You don't say! I mean, from behind the control panel......this machine has been in shop longer than the most senior tech! The boss called the lws for a quote on a replacement today... they have 'em on sale... must remain calm... ole blue bones can still be fixed!... But the machine repair facility is moving this week to a new shop...can the boss afford to wait?... Rumors of rising stock prices could mean an increase in business....this is no time to turn away work.... the anticipation is palpable!... What will become of ol' blue,... stay tuned for next weeks exiting episode of....."Spend The Boss's Money!" City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Maybe the problem was welding one-handed with the left hand and a tank with the valve closed??MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33Maybe the problem was welding one-handed with the left hand and a tank with the valve closed??
Reply:where abouts in LA are you, tanglediver?
Reply:Montclair/Ontario.Oh hey neighbor! Upland eh? City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:The old Miller ain't completely dead yet, just playin' 'possum!  It seems that the panel design which uses jacks and pigtail cables to switch from high range to low range and from electrode positive to electrode negative have left them in vulnerable positions. This was probably kicked by accident and the very small amount of plastic insulation between the hot cable and chassis ground was compromised. In other words, it shorted out! Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:From the looks of that male pin connector and cover Danny I'd say a poor connection caused the assembly to heat up to the point the plastic insulator nut melted allowing the female connector body to make contact with the chassis rather than an errant kick.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-20 21:23 , Processed in 0.114991 second(s), 19 queries .
