diesel welder
发表于 2021-9-1 00:45:02 | 显示全部楼层 |阅读模式
how do i tell if my 250 lincoln perkins has murphy system? it is a older machine. i also have a 96 lincoln 300 perkins it has a engine protection switch the 250 doesn,t , would that be it?
Reply:The gauges should say Murphy on them and have little contact stops in them that are adjustable.  But if you question whether it has a Murphy setup or not, it probably doesn't.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-20 18:44 , Processed in 0.090338 second(s), 18 queries .
