Rear frame fabrication
发表于 2021-9-1 00:45:00 | 显示全部楼层 |阅读模式
Hi guys I’m working on a 67' ChevII and I’m doing a custom 3 link on it. Im replacing the frame rails and adding a cross member to mount the links to. Now I have the x member and the frame rails tacked in. I was looking at the whole deal and it looks like I can drop the whole pig out. My question is: now that I have the rear rails and x member tacked and measured out for the car, can I remove the whole unit and complete it out of the car? Or should I just weld it up in the car? Some of the parts I need to get to and weld are very hard to reach, this would make it alot easier as you can imagin. Request assistance please Anchors
Reply:Drop it out after you make meticulous measurements.  Then make a jig to sit it on to counter all the warpage it's gonna have.  Once you get it welded, take it loose from the jig & correct the warpage so it fits correctly.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
GMT+8, 2025-12-20 18:46 , Processed in 0.098839 second(s), 18 queries .
