looking for a welder plzzz help
发表于 2021-9-1 00:45:00 | 显示全部楼层 |阅读模式
im looking for the name or type of wire feed welder that you hook your ground clamp and your stinger to power the wire feed welder    do you no the type and name ?
Reply:Like a suitecase welder?? Like this?? http://www.millerwelds.com/products/...se_x-treme_vs/Miller 252Miller 250Miller Syncrowave 250Esab Plasma Powercut 1250HF Basic oxy/act torches
Reply:yes thanks
Reply:Lincoln LN25 and Hobart Hefty are similar to the Suitcase VS too.  The Hobart is now made by Thermal Arc.  I forget what they call it now but it's basicaly the same feeder as the Hefty with a different name on it.  The older Miller S32P (I think that's the right number) is another one.These can be used on any welder with + and - connections available, but work best with a Constant Voltage (wire) capable machine, rather than a Constant Current (stick/tig) only machine.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:thanks
Reply:i jest got a miller bobcat 225g plus portable welder to start doing on call jobs.  What portable wire feed would work the best with my bobcat?  Most of the steel thickness is 1/4 to 3/8 thick that i well be welding
Reply:any one that does not have a remote cable, as your bobcat doesnt have a remote plugmiller VS feder would work, but not the RC ones.that is just an example as some of the others would do also.as long as they dont have the remote cable and your all setG
Reply:The feeders I mentioned above will all work.   I think there are both volt sense and remote control versions of the LN25 tough so be careful which one you buy.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-20 20:22 , Processed in 0.093873 second(s), 18 queries .
