Welding aluminum with a MIG
发表于 2021-9-1 00:44:55 | 显示全部楼层 |阅读模式
HiI have a miller 185 mig,is it possible to weld alum?If not what da ya suggest without purchasing a tig.ThanksAnchors
Reply:Originally Posted by smithmiller6HiI have a miller 185 mig,is it possible to weld alum?If not what da ya suggest without purchasing a tig.Thanks
Reply:youre best option is to try and find the spoolmate 185 spoolgun for the 185.I beleive the 3035 is the same hookup but check first this will let you do aluminum with 100 % argon gas.lol                  FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:The Lincoln 180C does Al,  you can get plastic liners for the gun, and if you are very careful to keep the lead straight you can probably feed Al wire. I am ASSuMEing that the 185 would be similar. If you are going to do much of it you would be better doing as FM says and  getting a spool gun.-- fredLincoln 180C MIG
GMT+8, 2025-12-20 20:22 , Processed in 0.102522 second(s), 18 queries .
