Welders4less regulator/flow meter
发表于 2021-9-1 00:44:50 | 显示全部楼层 |阅读模式
Hi all,did a quick search, but didn't find anything.  Has anyone used the Welders4Less regulator/flow meter? (http://cgi.ebay.com/Carbon-Dioxide-C...3%3A1|294%3A30)At $28 it seems like a deal... Also, does anyone have a good reference to gas type with MIG welding?  I've been doing FC so far, and am about to give shielding gas a go, but don't want to buy two bottles.Thanks,Matt
Reply:I have 2 of them. One for the Hobart, one for the Lincoln.  I used the ones that were specifically set up for MIG gases, the 580 sized connection.  I set mine at about 15 CFM & run 75/25 Argon/CO2.  Depending on what you are welding, that is pretty much a standard for MIG gasses.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:75/25, CO2, 98-2, 95-5, AR, He, AR/HE.  What do you want to weld.  JGSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
GMT+8, 2025-12-20 18:48 , Processed in 0.090848 second(s), 18 queries .
