New to Welding, Looking for a welder that fits my needs
发表于 2021-9-1 00:44:47 | 显示全部楼层 |阅读模式
I'm looking to buy my first welder. I will be using this welder for minor fabrication projects that come up during my newest car rebuild. After my last few projects experienced stalls do to minor fabrication delays due to welding shops. I figured that pick up welding wouldn't be a bad idea.I'm looking for a welder that is capable of the following welding needs:  Stitch welding a uni-bodyTubing Fender WellsFilling/Shave body holeExhaustMaking braces/cage
Reply:Check out Hobarts line of Handler MIG welders on there website.  There 175 would suit you pretty good I think.  Others will be able to help you much more..But I think if you look at the Hobart Handlers you should be able to find something to fit your needs.Tom
GMT+8, 2025-12-20 18:47 , Processed in 0.149661 second(s), 19 queries .
