$250 welding job
发表于 2021-9-1 00:44:47 | 显示全部楼层 |阅读模式
Reply:Not going to lie...those look like some grizzly welds. Looks like over build up on the first picture...wow.But hey if it holds and does what the customer needs I guess thats all that you really HAVE to achieve.'Mike
Reply:More weld does not always = better.  Same goes for extra thick gussets....Now I know I am under charging.
Reply:Did you use a knife and fork?
Reply:What is that in first pic, and why?The major part in welding aluminum is prep, clean, clean, clean. Then weld. If base aluminum has been in service and contaminated, pre-heat will help, removing soaked in oils.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:I'm gonna guess someone paid for the $250 welding job and something failed.  Then they bring it to LoudnProud here, and said "I paid $250 for this welding job, can't believe it failed"LoudnProud gives said customer a quote to fix it, and post pics because he can't believe some of the hacks out there, charging money without knowing what they're doing.I bet the customer said one of the two things,1. "WTF? most of the stuff is welded already, why charge me so much to fix it?"2.  "Just fix it, and do it right, i dont care how much it cost, i'm sick of dealing with cheap weldors"so, am i right?  hey look on the bright side, pic one does have a lot of filler.  Since i just started welding aluminum a couple of weeks ago, i had to buy some rods... and they're expensive.  that's at least $20 worth of filler in just the first pic.
Reply:What happened there? Kinda looks like someone did a butcher job.DaKK
Reply:WOW!!! Beautiful!! I hope you did not pay someone for that. 3M TA3
Reply:The sea gulls must have been flying over that job ,,,any chance of a refund
Reply:Are you showing off your work, showing what you need to fix, or just a "hey, looky here"I hate it when people make threads with an absolute lack of information.Have we all gone mad?
Reply:The first one is amazing!San Diego Welder Welding in San Diego
GMT+8, 2025-12-20 18:44 , Processed in 0.106645 second(s), 18 queries .
