I lost my mind, I bought a diesel LINCOLN!!!! pics
发表于 2021-9-1 00:44:45 | 显示全部楼层 |阅读模式
I think I need my head looked at.  I needed a big diesel drive welder, so I went shoping for one.  As y'all know, I am a huge fan of Miller welders.  But somehow I let this lincoln followed me home.     Its 1999 Lincoln 300 commander.  With a whopping 683 hours on it, and I know that 210 of the hours was used during a power outtage during a hurricane.  I also basically stole it for $5000.It belonged to my mentor.  It used to be painted ford purple to match the truck it was mounted too.  Along with a massive flame paint job.  After he sold the truck it was one, he had it repainted to match the new truck.  He even replaced all the panel fastners with stainless steel and had the bottom linex.   This baby has all the goodies.   Its 400 amp DC CC and 45 volts CV being driven by 33 hp deutz diesel!!!   Now I just got to get around to finishing my all aluminium welding bed for my F-250.  Because its way to heavy for my little F-150.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Damn pictures didn't attach. Attached ImagesLincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:wow must be nice to have that hog of a machine! you didnt lose your mind, you just made a good investment!
Reply:Should be a good machine. My friend and competetor has a 400 Commander. Last time I walked by it the hour meter was almost to 5000 hours.
Reply:Jebus....Now you need a bigger truck or a coupe more leafsHere learning to turn down the Suck...
Reply:nice machine!I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:The truck looks like it's holding back tears of PAIN!That thing is a beast!  Good score!
Reply:Like I said its going on my F-250.  I am almost done with the custom welding bed, which was built just for this machine.  (I knew I was going to get it a month ago)Btw that F-150 has had the frame sitting on the axel numerous times.  We I used to have a landscape company my employees always over load it.  (hence all the dings and dents in it)  But its my half ton beater, so I am not that worried about it.  Going to replace it here in the next year or so.Last edited by Xtreme Fabrication; 07-03-2009 at 08:19 PM.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Dang!  That thing is HUGE!  It's not what you can buy, it's what you can build.
Reply:Nice!  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:You might want to think F350 for that monster. What does it weigh?
Reply:You did steal it!  Nice machine.  (poor little ford)David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:1300lbs wet.  I know of another guy who has a commander on a pipeline side in bed unit in his F-350 single wheel.  Which still leaves the 650lb pickup bed, plus the 400lb side in unit.  My aluminum welding bed is coming in at about 475 lbs, so my weight savings is making up for this "Big Boy"Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:You could power the neighborhood with that thing!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Those knobs are kind of small... Have you lost your mind? City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:It says on the machine its only 50 amp and 10,000 watts.  But according to my mentor, when he had his house running off it during the hurricane.  He had 3 a/c units, oven, tv, computer, all the lights on, etc. at the same time.  He did say that it didn't have enough power to run the dryer too.   I do remember reading some where that the AC power on these is really like 25,000 watts.  As for the knobs, I think they are too big.  But you can tell what setting the machine is on from 500 ft away. Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:That's nice.  Congratulations!!"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Congratulations on the new unit green.  Awesome!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:ran a commander 500 for several months. sweetest machine i ever used.insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Originally Posted by zapsterYou could power the neighborhood with that thing!...zap!
Reply:Well I finally got to play with it today.  I threw my spool gun on it and WOW!!!!!!!!!!!!!  Its like night and day compared to running my spool gun on my old bobcat 225g.  Such a smooth arc and 100% better power.   I got some stick welding to do on monday.  So I will play with it then.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Originally Posted by tanglediverThose knobs are kind of small... Have you lost your mind?
Reply:So now that you have switched from Miller to Lincoln are you going to get a respectable Chevy to put that thing in!!!!!Nice machine, and a good steal!
Reply:the bobcats and rangers are nice and handy but they are chevys compared to that lincoln your now driving.I have never met anyone who did not think the commanders were the best machines lincoln ever made, closely followed by the SA-200 and its brethren.(great arc gougers as well)insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:I was hoping it was a good air gorging machine.  I got about 50lbs of 1/8" to 1/2" arcair rod given to me for free a couple of weeks ago.  My landlord wants me to replace the cutting edge on his farm tractor.  Now I got the machine to do it.  I am glad to here its consider one of the best.  But I did think nothing else lincoln made came close to a sa-200 pipeliner.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokersnothins finer than a pipelinerpipefitter/welder 7 yrsgeneral foreman 2 yrs working in the fabrication, chemical and petrochemical industry 7 yrsNCCER CERTIFIED-PIPEFITTER, IRONWORKER, WELDER STOP SNITCHING
Reply:Wow..Nice Machine...Haha.couldnt imagine that sitting on my poor little 150.  Any pics of the truck bed?
Reply:I will post pictures some time this week when I get the bed finished  Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
GMT+8, 2025-12-20 18:46 , Processed in 0.073320 second(s), 18 queries .
