Lincoln 180HD vs. 180T
发表于 2021-9-1 00:44:35 | 显示全部楼层 |阅读模式
Ok guys, I have searched these threads and multiple other forums and I can't find a difinitive answer.  What is the difference between the 180HD from the big box store and the 180T at the LWS?  I have read the specs on both machines from the Lincoln website and I cannot find one single difference.  Please help.
Reply:Hi Tiger Fish, one difference is that you'll usually save some money buying from the big box store like Lowe's, Home Depot, Northern Tool. Saving the extra bucks is nice if your really sure about your purchase! But if you have any questions about your selection of welder you'll find those folks at those stores do not have the knowledge to answer welding questions. Your local welding supplier will be able to answer your questions about your selection of welding equipment and supplies to go along with it.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:They are the same machine with different namesThe only Lincoln machine that is different and better is the Power Mig model.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Here is a reconditioned 180T for 545.00http://www.weldingmart.com/Qstore/p003823.htmNew 180HD @ Home Depot runs around 669.00New Power Mig 180 runs around 758.00 (on line)Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:HD = Home Depot Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Thanks guys.  I appreciate the help.
Reply:If I were you, I'd go out and spend the extra cash on the powermig 180. It is a better built machine with longer lasting components, such as the drive roller housing is made out of aluminum instead of plastic.Miller Dynasty 300dxSpeedglas 9002XMiller Spectrum 375 XtremeLincoln PowerMig 255xtLincoln PowerMig 140cMilwuakee Portaband
GMT+8, 2025-12-20 18:45 , Processed in 0.107312 second(s), 18 queries .
