cast aluminum welding
发表于 2021-9-1 00:44:33 | 显示全部楼层 |阅读模式
hey guys.i want to know if you can weld ,what i believe is a lawn chair made of cast aluminum ,i  see welds on it and different points,the chair is very lite in weight ,but right where the right arm meets to the back of the chair, the weld broke off.i have a small mig ,a stick welder  and a new 185 thermal arc tig welder ( which i dont no how to use yet).( dumb ***)what would you recommend .if no welding what about an epoxy,thanks
Reply:JB Weld will get it...I am sure it is really thin not a good thing to start learning to weld Alum.....BrandonLincoln Tombstone 225 A/C Steel StickerOld Victor O2/Acetylene setupMiller Syncrowave 250 Tig/PC-300 PulserMiller Millermatic 212 Mig HTP Invertatig 201 Giant Teck D50 Plasma cutterLots of HF grinders
Reply:If you can afford three welding machines I say GET A NEW CHAIRIf you want to do it for the challange--- tig w/4043Peter
GMT+8, 2025-12-20 18:44 , Processed in 0.313928 second(s), 18 queries .
