Anyone here cert people?
发表于 2021-9-1 00:44:32 | 显示全部楼层 |阅读模式
I have some questions and want to know if anyone here cert students here. Please let me know
Reply:You need to talk to member Lloydeo...MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Ok i give, whats cert people mean? Does it hurt? Is it legal? Honestly have no clue!
Reply:Give certification cards from AWS to students
Reply:He's asking for someone who oversees/administers/signs off on weld certification tests.   There are a couple members here who do that.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:For an "AWS Recognized" certification that "MAY" carry weight with multiple possible employers and minimize the need to retest, I suggest contacting an AWS Accreditied Test Facility.Manufacturers/Companies usually have the reposibility for testing and qualification of their welders however some codes allow certifications for previous organizations to be accepted.There is no special requirement for who conducts your test and documents the test however with a known organization or individual , the testing may carry more weight with companies.There is no seperate "certification" for students. However there are hundreds of possible tests that could be given depending upon what you are going to do in production. Normally a test is given that covers as many production ranges as possible however it can also be as simple as welding a tee joint flat or horizontal (though easy, the penetration can get you ).For a test to be given the organization needs a Welding Procedure, Equipment to weld with, known materials, and someone to perform destructive or non-destructive testing . Thats it . To become an accredited test facility, much more is needed.GeraldHave a nice dayhttp://www.weldingdata.com/
Reply:Ok thnx for the information!
GMT+8, 2025-12-20 18:46 , Processed in 0.065038 second(s), 18 queries .
