transporting argon/co2 tank
发表于 2021-9-1 00:44:31 | 显示全部楼层 |阅读模式
Do you guys have your tank/refill delivered to you or do you just get yours and put it in the back of your pickup truck? If in the back,how do you strap it safely?
Reply:I have a piece of 6" channel two feet long I lay the tanks in to keep them from rolling around And I ALWAYS load them w/ valve toward the cab so if something bad happens it'll go thru the tailgate instead of me.                           MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Lay it down in the bed, chock it so it doesn't move, and don't drive like a knucklehead.Remember that if you lay down acetylene tanks, you need to store them in an upright position for a few hours before using them.  Then ensures that the media and acetone inside are settled into the proper position and won't get sucked into the valve.All other types of tanks commonly used for welding can be stored and used from any position.  It's only the acetylene that needs to be upright.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:Easy to put a couple tie starps through the hinge of the tailgate and down around the bumper or trailer hitch, close the gate and add some pull to keep the tank held down flat against the tailgate.Last edited by Timberwolf; 07-23-2009 at 12:38 PM.Lincoln PT185 TIGLincoln 175 MIGLincoln 240 amp AC StickLind Needle Arc plasma welderPlasma cutter, soon???
Reply:While I'm set up for delivery, I usually just go pick up the tank. In the pickup I have a coulp of big 4"x4" 1/2" thick chunks of angle iron I use as chocks to keep the tank from moving around. The other trucks I can either lay them down or strap them upright to the side wall or ladder rack.
Reply:I always transport with the regulator removed from the tank and the safety cap securely threaded on the tank.  The bigger tanks (250 cf and up) I lay down in the bed of the truck or van and chock so they won't move.  The smaller tanks I stand up in their usual spot between the tool boxes and tie off to the pipe rack.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Laying a tank full of high pressure gas horizontal position is not a good idea. I checked the OSHA regs and it’s a BIG BIG NO-NO to transport any gas cylinder in the horizontal position. The cylinder MUST be in the up-right position and secured from moving in all directions. You’re taking a big chance if anything goes wrong, no insurance and jail time.
Reply:Better to be already laying down than standing up and falling over....MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I agree.For what it's worth, for the smaller inert gas hobby tanks I usually have no problem throwing them in the trunk of my car, no reg, protective cap on. Anything larger than 80cf or anything active goes a pickup truck.
Reply:Originally Posted by transitLaying a tank full of high pressure gas horizontal position is not a good idea. I checked the OSHA regs and it’s a BIG BIG NO-NO to transport any gas cylinder in the horizontal position. The cylinder MUST be in the up-right position and secured from moving in all directions. You’re taking a big chance if anything goes wrong, no insurance and jail time.
Reply:Originally Posted by DesertRider33Better to be already laying down than standing up and falling over....
Reply:Transit, do you have a link to that OSHA reg? I'm thinking that the reg may or may not apply to many, as a personel vehicle would not fall under OSHA regs, but would probably fall under DOT regs for transport.
GMT+8, 2025-12-20 20:22 , Processed in 0.090282 second(s), 18 queries .
