Looking for a manual for a Linde H 250 HF
发表于 2021-9-1 00:44:30 | 显示全部楼层 |阅读模式
Please help I am looking for a manual for a Linde H 250 HF , and if someone can tell me what kinda of pedal I can get that will work on this machine. Plase let me know.                                     Thank You
Reply:Check with Joshua Miller at Arc Products http://www.arc-products.com/.  I believe he can get you squared away on a manual.  Be advised there is a small fee for them but they're quality reproductions with clear illustrations and if they have one you can probably also get them in .pdf format so you can have an electronic copy too.He should also be able to clarify any remote foot controls that will work with the unit.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Take this with a grain of salt, since I googled it out of curiosity.Linde was bought out by Esab a while back.http://www.esabna.com/literature/Arc...wer_Source.pdfAnd on the pedal:I remember a few years back (not sure though) that I saw a shop which used a Miller pedal with seperate contactor/amperage Hubble style connectors to run their older HF250. The Miller RFC23A pedals meets those criteria. Some of the more experienced guys at SFT may have a definitive answer.
Reply:Thanks alot guys I will give them a try I was getting no where before
GMT+8, 2025-12-20 20:22 , Processed in 0.094443 second(s), 18 queries .
