storing 4'x4'x.5
发表于 2021-9-1 00:44:27 | 显示全部楼层 |阅读模式
the supplier delivered the material for my welding table.  it will take me a few days to get started on it, so how do i store the top so it wont warp?  Its now sitting on the concrete floor in the garage.  it will likely be there for up to a week.  should be fine, right?  should i get some card board to raise it up 1/4 inch or so?the plate is 4 foot square, 1/2 inch thick.
Reply:unless you drive the car over it the piece should not warp.  Lean it against the wall, or lay it on the floor.  it will be fine.  1/2" plate takes a pretty good load to warp it.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Just let me know where its at and I'll take care of it for you!BTW what did it cost?
Reply:three 20' 2"x2"x1/8 and the 4' sqare plate for $305 delivered
GMT+8, 2025-12-20 20:25 , Processed in 0.099026 second(s), 18 queries .
