old westinghouse welder
发表于 2021-9-1 00:44:22 | 显示全部楼层 |阅读模式
A friend gave me an old welder--orange with blue top--If i knew anything about Windows XP I could post picture but am still working on that. Let me describe face of welder --Number grid on front side with 5 vertical colums and arrows pointing to 5 female plugs at the top of each--4 horizontal rows with arrows pointing to 4 female plugs on right side of rows. top rowe has # 28,46,74 118,180. 2nd rowe 25,41.66.104.163; 3ed rowe 22 36 58 93 147, last rowe 20 32 52 83 132. I get + goes into one of plugs ,horizontal or vertical - goes in other--Which goes where? how do I read amps??
Reply:Here take a look at the picts I posted here and the description of how it works and see if it helps.http://weldingweb.com/vbb/showthread.php...ight=craftsmanPicts of your machine would make this easier. What is the problem you are having with the picts, perhaps someone can help..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by runks2075. . . Let me describe face of welder. . . .. . .I get + goes into one of plugs ,horizontal or vertical - goes in other--Which goes where? how do I read amps??
Reply:denrap--I think you got it --heavy heavy with handle on each side---switch is ok--I have 5 holes accross top., 4 vertical on right --  but I think i understand what you are saying--looks like thats it--thanks much--will work on picture posting now !!
GMT+8, 2025-12-20 20:27 , Processed in 0.093956 second(s), 18 queries .
