how many different welding machines are there
发表于 2021-9-1 00:44:21 | 显示全部楼层 |阅读模式
like, how many MIG machines for example are probably currently in use, like diff models, different brands, etcand is it difficult getting used to a new machine or are they all very similar?
Reply:Two.  Those that work and those that don't.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Hello snappy101, Duane's answer is one of the most accurate answers that you will probably receive. It really is true that some work and some don't, they also work to greater and lesser degrees. Now to the more serious part of your question: there are probably literally tens of thousands of different machines and variations out there. They likely have many similarities that are shared and as many that are not. Basic machine design is another topic and has way less choices. Here are a few: transformer/rectifier, motor/generator, inverter, CV, CC/voltage sensing, various hybrid systems that incorporate a number of the basic systems in unison or otherwise. Earlier home welding options were probably of the transformer rectifier type and generally used either tap voltage selection with variable wire speed or "infinite" voltage selection along with the variable wire speed. Now there are more of the home type units that are of an inverter type. There are some pronounced differences between the inverters and the more traditional transformer/rectifier types, you should google "inverter power sources" and then do the same for "transformer/rectifier power sources" and read and compare. In short however, the inverters are much lighter and generally more efficient than the transformer/rectifiers. They are also generally much more expensive. A few items for your consideration. Best regards, Allanaevald
Reply:Snappy, Google to, history of welding. It’s amassing how many of the companies started, anyone with a wrench got into the business, sink or swim. Lots of links to other history sites, something to do on a rainy day.
Reply:snappy101,Accurate or not, I didn't mean for my response to come across as 'blowing off' your question although I'm sure it did.  My apologies to you.Obviously Allan and transit did their usual awesome job of addressing your question properly and as you can probably tell the answer is a big one.DuaneMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55snappy101,Accurate or not, I didn't mean for my response to come across as 'blowing off' your question although I'm sure it did.  My apologies to you.Obviously Allan and transit did their usual awesome job of addressing your question properly and as you can probably tell the answer is a big one.Duane
Reply:Originally Posted by snappy101like, how many MIG machines for example are probably currently in use, ?
Reply:how long does it usually take to adapt to a new machine though usually?
GMT+8, 2025-12-20 20:28 , Processed in 0.090552 second(s), 18 queries .
