longer gas hose?
发表于 2021-9-1 00:44:17 | 显示全部楼层 |阅读模式
The gas hose on my KARC 100 looks to be about a foot and a half long meant for small cylinders,can this be extended to reach a full size cylinder?
Reply:LWS should be able to  make you any length you need.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:If I get a chance I'll go to the LWS tomorrow and check that out,thanks
Reply:Gas hose can be made to most any length at the LWS.  I have a 125' hose on the truck that I use from time to time with my suitcase feeder.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Originally Posted by Hammack_WeldingGas hose can be made to most any length at the LWS.  I have a 125' hose on the truck that I use from time to time with my suitcase feeder.
GMT+8, 2025-12-20 21:47 , Processed in 0.099128 second(s), 18 queries .
