Mobile welding.
发表于 2021-9-1 00:44:16 | 显示全部楼层 |阅读模式
This seems like a pretty good idea to us a box truck, I have never thought of it.http://www.realpagessites.com/jnmobilewelding/“Great works are performed, not by strength, but by perseverance.” “Marriage is a three rings circus: engagement rings , wedding rings and sufferings.”
Reply:That is really cool. Those machines must weigh a TON.. Literally!! espically those mills and lathes.I always thought about having a mobile machine shop.
Reply:The problem with using an enclosed box body truck as a mobile welding rig is your engine drive welding machine will burn up inside that hot box unless alot of work is done to ensure it's ventilation.    Easier and more convenient to just use a utility bed truck.   The welding machines are fine being kept outdoors, the weather doesn't hurt them.   They make fabric covers for them too.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-20 20:21 , Processed in 0.098123 second(s), 18 queries .
