Trailblazer 251 NT questions
发表于 2021-9-1 00:44:15 | 显示全部楼层 |阅读模式
Evening Folks,I have searched the site but have not come up with the answers to my question.  What are the specs and capabilities of the 251NT and what current trailblazer is the most comperable to the 251NT?Thanks, Bo
Reply:Hey i have one of these machines. Runs great. What do you want to know?? I have the 20 hp Owen engine.
Reply:Originally Posted by Ag SpecialtiesHey i have one of these machines. Runs great. What do you want to know?? I have the 20 hp Owen engine.
Reply:I have an '04 Bobcat 250NT.  Mine has the Kohler gas engine.   Both the Bobcat and Trailblazer of that era are 10KW generators, which amounts to 44 amps @ 240 volts and 88 amps @ 120 volts output, with a pair 120v outlets and a single 6-50R 240v outlet, all single phase 60Hz.   GFCI 120v outlets were optional.   The T-Blazer 251NT should have a ~250 amp CC @ 100% duty cycle output with ~300 amp max on CC or CV.   I forget what the specs are for the AC output.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-20 20:29 , Processed in 0.435994 second(s), 18 queries .
