Aluminum spoolgun wire?
发表于 2021-9-1 00:44:12 | 显示全部楼层 |阅读模式
anybody know if all wires are created equal, I am having feeding issues as I get near the last 1/3 or even 1/2 of my 4043 wire. Seems to kink more and I get a burn back. are any of the wires wound better or easier to use. Is 4043 what I want or 5056 better? I think I have my numbers straight but not sure."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:I prefer 4043 myself.  And if you are using that 30A the tension on the drive rollers and the tension on the spool can be finicky.  Last time I used mine I was running about 19volts and pushing the gun.  I don't remember what the wire speed was, I kinda think I remember the dial on the gun was 4.5, but I have no clue what the display said.
Reply:I see from the listings, for non-critical maintenance work ER4043 is commonly used. The rule in selecting the electrode is to match the alloys and use wire recommended by the manufacture of the base metals. If you replace the ER4043 with ER5356, 5000 series wires will be stiffer than the 4000 series wires. Because of the higher magnesium content, ER5356 has a faster burn-off rate and requires a faster wire feed or you’ll have problems with burnback to the contact tip.
Reply:kolot,Same setup as you're using.There is quite a bit of difference in wire (how it's spooled) from different manufacturers.  Just have to find one that works well for you.I, personally, probably use 5356 three to one over 4043.  Wire is a little stiffer and tends to cause less feeding issues.  As has been mentioned, you'll have to increase your WFS over the numbers on the door chart (those numbers are for 4043).Some of the burnback issues you're encountering could be caused by the selection of tips you're using.  Are you using a recessed tip for aluminum?  Are you maintaining adequate stickout (aluminum dictates more)?If we knew what tips, nozzles, etc you're using, we possibly could be of more help.  The number of diffusers, tips, nozzles for the 30A can be somewhat mind boggling.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
GMT+8, 2025-12-20 20:19 , Processed in 0.089675 second(s), 18 queries .
